F 806 L
extxdep
10-17-2004 19:25:46
My grandfather has an 806 that has some problems. First off the starter is shot and the parts store said I need a year model. I have no idea the serial number is 2518S-Y. I have read on these boards that someone can find out the year model from the serial number. I've looked everywhere and cant find it. My second question is that this tractor runs off of LP. Before the starter went out you had to run full choke to keep her from dying, but it got to the point to where she wouldnt run at all. We changed the fuel filter and put in fresh LP. She ran for about 10 minutes then died and wouldnt start again. The tractor has an Ensign C123 carb. I was wondering if anyone can give any advice on the settings for the adjustment screws and possible causes of this problem. Thank you for any response.
K.B.-826
10-18-2004 19:52:45
 Re: F 806 L in reply to extxdep, 10-17-2004 19:25:46
Without actually looking up your serial number, I'd say it's a '63. It's the 2018th 806 built, anyway. I'm with Novel Idea Guy on the starter, model year dosn't make a difference, all six-cylinder non-diesel IH's 06-86 series will have the same starter. Probably won't find too many LP experts around here, IH didn't build many LP burners. Mabey get an I&T manual and see what it has to say.
Novel Idea Guy
10-18-2004 11:31:24
Look to your left. Under Research & Info for Serial Numbers.
As far as the starter goes, it shouldn't matter what model year. They've only got a few different starters for the 06-86 tractors, and they all fit.
