1206-1256
IH novice
10-18-2004 15:49:15
Whats the difference between the two other than the number? Not a IH guy and have found Two 1256's, both with bad transmissions. Is this common on these tractors? I would think that it would be a wonderful loader tractor and I know it would handle my snowblower. Thanks
karl f
10-18-2004 20:24:40
 Re: 1206-1256 in reply to IH novice, 10-18-2004 15:49:15
our 1256 had the tranny out about 15 years ago. so it can happen.
for a loader tractor, i dont think so! unless they have hydraulic assist clutches, you will regret using them as a loader tractor after about 20 minutes...gotta have a real strong clutch foot.
otherwise a great powerhorse and one of the sweetest sounding diesel engines...and relatively quiet too. if well tuned, will start fairly well in winter if coolant heaters are used.
-karl
Dan 3588
10-18-2004 16:46:08
I don't believe so. We have an 806 and a 1256 with over 10,000 hours on each and no tranny trouble. What do you mean by bad transmissions? The main difference between the two in the shift on the transmission. The 1256 has a 407 turbo, the 1206 has the 361 turbo. Far as I know, unless your pulling, but are rated around the same hp, both can be turned up considerably. For loader work, the 56 shift is nicer. You can go from reverse to high without going through low.
