1948 H Distributor
Tanner
10-19-2004 11:14:15
Now that I am thick into my restoration, I cleaned up and took apart the Dist. I split the main housing in half and some liquid came out. I believe there should only be grease in it. Also shouldn't the large gear on the Dist. be turning freely? It does not move right now, and since I seperated the main housing I will also need a new gasket or use gasket maker because it is leaking the remaining fluid. I think water just got into the Dist. some how, and maybe that is why the gear is stuck. Any ideas guys?
Geoff NY
10-19-2004 13:53:28
 Re: 1948 H Distributor in reply to Tanner, 10-19-2004 11:14:15
Are you talking about the distributor housing or the coupling that it fits into? A lot of them have tightened up due to sitting for years and need to be taken apart cleaned and freed up, at least that is my experience Geoff
Bob Quale
10-19-2004 16:23:01
 Re: 1948 H Distributor in reply to Geoff NY, 10-19-2004 13:53:28
I just got a used one in great condition from Steal Wheel Ranch with the gear drive. Turnes out I am not going to need it. E-mail me if you need one.
Bob
