Farmall A not charging?
Andrew Z
10-19-2004 11:41:28
My "A" is not starting via the starter, the starter will ingauge the ringgear but only turn it a 1/8 of turn and stop. When it is running wide open it shows a 20 amp charge, yet if you shut it off for 10 mins. and come back it still will not start. the battery is only about 5 months old and its a deep cycle. What might the problem be?? Thanks for the help Andrew
old
10-19-2004 11:53:45
 Re: Farmall A not charging? in reply to Andrew Z, 10-19-2004 11:41:28
The battery is your problem, a deep cycle is made for slow charge and long discharge. Try a differant batery even if you have to borrow it from your car and you will probably be ok
