what do i have?
cajunace
10-20-2004 16:04:44
my grandfathers old farmall was sold away a few years back after he passed away.last week i had the chance to buy it from the man that it was sold to.so i bought it, but now i"m lost as to what model it is.the man said it is an A model.all i have to go by is the number stamped on the plate under the seat.it begins with 3363.can"t read the rest. can any one help? thanks
Glen Thibodeaux
10-20-2004 18:07:39
 Re: what do i have? in reply to cajunace, 10-20-2004 16:04:44
Hi Cajunace,
I can help you identify your tractor. Where are you located? I'm in Carencro.
Thanks,
Glen
cajunace
10-21-2004 14:02:01
 Re: what do i have? in reply to Glen Thibodeaux, 10-20-2004 18:07:39
hey, glen im from plaisance between opelousas and ville platte just down the road
Glen Thibodeaux
10-21-2004 20:12:58
 Re: what do i have? in reply to cajunace, 10-21-2004 14:02:01
I know where Plaisance is, how far off HWY-10 are you? Have you found out what model tractor you have? What is the condition of your tractor? Do you plan to restore it?
Glen
cajunace
10-22-2004 14:33:11
 Re: what do i have? in reply to Glen Thibodeaux, 10-21-2004 20:12:58
yes i plan to restore it. but i will use it for a little truck patch behind the house. im just glad to have it back in the family.
parts man
10-20-2004 16:15:43
You will have to give us the letters ahead of the number as well, and a description of the tractor. Do you sit beside the transmission, or above it? Wide front or narrow etc.
cajunace
10-20-2004 16:49:04
 Re: what do i have? in reply to parts man, 10-20-2004 16:15:43
the letters FAA-v are stamped under the #"s. i sit beside the trans.the front tires are almost as wide as the backs. one older fellow told me that it probably was used in the cane rows way back, because it is a little taller.
Stan(PA)
10-20-2004 17:43:40
 Re: what do i have? in reply to cajunace, 10-20-2004 16:49:04
It"s a Farmall AV, but the FAAV should be before the number, not under it. Check for the whole #, sometimes wetting it helps. How many numbers follow the first four?
cajunace
10-21-2004 13:59:02
 Re: what do i have? in reply to Stan(PA), 10-20-2004 17:43:40
i did get the other numbers finally, the whole # is 336339.
parts man
10-21-2004 16:01:38
 Re: what do i have? in reply to cajunace, 10-21-2004 13:59:02
She's a '53 super AV
cajunace
10-21-2004 16:59:52
 Re: what do i have?/ thanx in reply to parts man, 10-21-2004 16:01:38
hey thanx alot fellows now i have somthing to start with.i was just out in the yard "playing" with her. it looks like i have some work ahead of me. it has bad blowby and all of the wheel seals are leaking that amongst other things. but i know it is old and has many many hours. my papa used it to farm about 25 to 30 acres for about 30 years. thanx again!
