M Gear Shift Removal
MarkO
10-20-2004 16:23:38
Need to get that shifter outa there. Parts diagram show caps over the pin. Any ideas how ya get those caps off?
Nebraska Cowman
10-20-2004 17:50:16
 Re: M Gear Shift Removal in reply to MarkO, 10-20-2004 16:23:38
tap around on the edge of one of the plugs, it should lift enough so you can get something sharp behind it.
randy hall
10-20-2004 16:25:53
use a large punch and punch through the expansion plug and push the pin out.
MarkO
10-20-2004 16:44:08
 Re: M Gear Shift Removal in reply to randy hall, 10-20-2004 16:25:53
Well thats how I started with a 3/8" brass drift punch. It would not budge and I didn't want to break the casting. Thats when I checked and discovered the caps. So use a finer punch through the cap and then replace em?
Thanks Mark
randy hall
10-20-2004 16:56:56
 Re: M Gear Shift Removal in reply to MarkO, 10-20-2004 16:44:08
yes. the expansion plugs are 5/8"
