M, Carb, Float Needed
Adam Whitson
10-20-2004 19:45:29
Anyone have a source for an M Carb Float. Im in Central Kansas.
ABW
Terryc
10-23-2004 15:35:57
 Re: M, Carb, Float Needed in reply to Adam Whitson, 10-20-2004 19:45:29
If you dont find a replacement most flowts can be fixed, usually just a pinhole, dunk it in a can of water for a min or so, remove from water, heat ir with a propane torch, the hole will whistle just like a tea kettle, then repair with solder, water will be boiled out when you heat the float... takes some patience and a steady soldering hand but works great. Good Luck
dej(JED)
10-21-2004 05:27:56
Call Joe's Farmall in Clarion , Pa. (814-226-6214). They have them and ship UPS. It usually takes 2 days for delivery.
Randy in NE
10-21-2004 04:45:37
Try your local Case/IH dealer. They had the carb kit for my C when I needed that a couple of years ago.
