Re: fast hitch ponderings
Bill in NC
10-21-2004 08:13:08
However, from a small tractor usage perspective, having a single-point fast-hitch on a Farmall Cub or 140 is the ticket for plowing, then disking and then cultivating 1 - 5 acres. Sure beats crawling under the tractor and re-doing the drawbar (early Cubs and A sized tractors) and its also quicker (and safer) than backing-up, aligning and all the other work needed to get a three-point implement hitched. It's great un-hitching an implement and then hitching up to another implement without leaving the tractor seat (using a hook to lift the fast-hitch notch lock).
Hugh MacKay
10-21-2004 15:09:15
 Re: fast hitch ponderings in reply to Bill in NC, 10-21-2004 08:13:08
Bill: No question, fast hitch was the cats meow for the small tractors Cub, 100 series and even the SC, 200 and 230. I believe that one point set up on 100, 130 and 140 can not be matched even in 2004 for tillage tools like plow, disk and cultivator equipment on a small tractor. Superb dept control on a plow and you can hydraulically change that depth to precise settings on the go.
Where the problem came was big tractors pulling heavy pull type equipment. I had a 560D, and pulled items like 4 bottom trailer plow, 10 ft disk, 13 foot vibra shank cultivator and forage harvester or baler with wagon. In about three years that hitch was almost like pulling those implements with a 4 foot chain. Not really the ideal situation with pto equipment. Interesting part is once the hitch was rebuilt, it only seemed to last about 1 year and would need rebuilding again.
