H Two way Hydraulics
Kirk
10-21-2004 09:17:49
I picked up a two way valve with the original break away coupling. A couple of questions I have: Did I get a good deal for fifty bucks?
Would it be advisable to switch the breakaway to the new style couplers?
Do I need to plug the vent hole in the filler cap?
Thanks for replies KF
Novel Idea Guy
10-21-2004 14:09:45
 Re: H Two way Hydraulics in reply to Kirk, 10-21-2004 09:17:49
Take a look at a new spool valve, hoses, and couplers in a Tractor Supply catalog. $50 wouldn't even make a dent! If it works, you made out okay.
I would leave the breakaway couplers, as long as they work okay. They're safer; if you're pulling a trip hitch plow, and it unhooks, you don't rip the hoses off the tractor and send high-pressure hydraulic fluid all over the place!
Nebraska Cowman
10-21-2004 12:45:53
ya, you got a good deal or what!
you might have to plug the vent hole in the cap. I had to on my M.
