Farmall 504 3 point issues.
Kelly Mehling
10-22-2004 14:55:03
Hi, I have a 504, and the hydraulics seem pretty strong, however the lift is sagging slowly and the system has to constatly correct for it. (every 5 to 10 seconds, the lift jumps back up and inch or two) I've tried to toy with the draft controll, thinking that might be part of it, but no results. My question is, has anyone had this problem? Is it a stuck check valve, or is there an internal leak causing the lift to sag?
RAS
10-22-2004 15:57:36
 Re: Farmall 504 3 point issues. in reply to Kelly Mehling, 10-22-2004 14:55:03
It sounds to me the oring on the hitch cylinder is bad.
