706 OIL LEAKS
SAM B
10-23-2004 06:02:41
HAVE A 706 310D OIL IS LEAKING AROUND EXHAUST CHECKED VALVE COVER DONT LOOK LIKE IT IS LEAKING TOOK MUFFLER OFF OIL IN EXHAUST MANIFOLD WHAT COULD CAUSE THIS
Aces
10-23-2004 09:21:12
 Re: 706 OIL LEAKS in reply to SAM B, 10-23-2004 06:02:41
Sam don't know if I agree on the D310 being the worst, but will agree on not working it hard enough. The other thing is you don't have the right oil in it. This was a problem back in the 1960's & 70's that is why Harvester cam with there #1 engine oil.
Allan in NE
10-23-2004 09:35:49
 Re: 706 OIL LEAKS in reply to Aces, 10-23-2004 09:21:12
Aces,
Tell me about this oil thing. I've never heard of this before.
Did I miss a whole chapter somewhere along the way?
Allan
Aces
10-23-2004 14:37:28
 Re: 706 OIL LEAKS in reply to Allan in NE, 10-23-2004 09:35:49
Allan Yes you did miss a chapter. I will get a lot of comments about this, but I go by what I see and prove for myself. When Harvester that is how all the IH people refered to the compony as.
When Harvester came out with the 300 and 400 series engines in the 66 series tractors in 1971 we had problems with was knowen as slober ( oil and Unburnt fuel) out the exhaust. We first thought a lot of thinks. Unfortunatly engines got overhauled when thet di not need it and still slobered. It came down to oil as did the carbon in the gas engines different story same ending. The fix was to put the right oil we used IH #1 diesel oil in the engine and about 1-1/2 hours on the dyno at full load no more slober out the exhaust even if the hard wook backed off they stayed clean. If a person could find the old service buletons from back then this would be in them some place. As I said I will most likly get alot of slack of this but I believe what I prove to myself I did it enough times to believe it. Same goes for the gas 6 cylinder gas engines I remember one 656 with 100 hours on it new would not pull 50 HP on the dyno pulled the head cleaned the carben out put head back on new plugs IH #1 gas engine oil, no problem with 65HP no more plugs run for years. When this all started I went to a Harvester oil seminar ther story was that not crud the same. So oil componies got there crud oil any place they could get it and one formlar so did not make the same oil. Harvester made sure they crud oil came from the same crud oil so one formaler one oil.
CNKS
10-23-2004 19:54:48
 Re: 706 OIL LEAKS in reply to Aces, 10-23-2004 14:37:28
I have read about the IH low ash oil many times, but you are the first that has provided an explanation -- thanks.
SAM B
10-23-2004 17:44:06
I AM USING 15-40 OIL WHAT SHOULD I USE
Aces
10-23-2004 18:12:23
 Re: 706 OIL LEAKS in reply to SAM B, 10-23-2004 17:44:06
Sam something like the IH#1 engine oil
Allan in NE
10-23-2004 07:03:39
Hi Sam,
Maybe the other guys will disagree with me here, but I think that the 310 is the worst of the bunch about this.
You're not working it hard enough. It has to be rapped up and it needs to pull.
My view,
Allan
