MD injection timing
PA Steve
10-24-2004 18:26:05
What is proper injection timing for a '41 MD? It is currently set 4 degrees to the left of zero. I am assuming that marks to the left of zero are advanced. I am questioning because I rebuilt the tractor and want to verify that it is correct. Thanks for the help.
Redrider
10-25-2004 21:25:55
 Re: MD injection timing in reply to PA Steve, 10-24-2004 18:26:05
The IH manual PA Steve says to set it at Zero.
Haas
10-25-2004 07:02:47
Get a reprint of the service manual. Instructions are in there for timing the pump.
bones
10-24-2004 19:30:23
hey, what is your serial number. i have a 41 md also. serial number 35466.
Roger WI
10-24-2004 19:25:21
Steve, The way I understand it there is no specific setting. You have to move it one way until the engine runs rough, then move it the other way until the engine runs rough or smokes, and then move back between where the engine runs the best. It took me a while to do it with my MD as you have to take the cover on and off each time. Roger
