Help identify Farmall
KX
10-25-2004 11:11:37
I have a unknown, serial tag has 35414 S stamped but rest is bare and theres no sheet metal. It has a Torque Amp and LP engine. Block casting number 356980 R2, bell housing casting 359026 R2, trans casting number 358840 R1. Looks like a MTA, 350, or 450?? Any help appreciated!
DWV
10-26-2004 03:52:22
 Re: Help identify Farmall in reply to KX, 10-25-2004 11:11:37
Going to disagree, numbers will fit SMTA and 400 series except chassis serial # and engine cast #. Engine cast # for SMTA and some early 400, 356980R1 not R2, chassis serial # only fits Farmall 400, MTA started 60001 and up, 450, W400 and W450 serial #'s never went that high.
KX
10-26-2004 10:00:09
 Re: Help identify Farmall in reply to DWV, 10-26-2004 03:52:22
Thanks To ALL for your help. I am going to assume it is a 400. It is in rough shape but not stuck and tranny seems loose so I will give it a chance to live again. Will see how the $ holds up.
sammy the RED
10-25-2004 18:37:11
The part numbers you gave are not correct.
One is for a Super M, Super M-TA.
Another one is for a W-400, 400 or a W-450 and a 450.
DWV
10-25-2004 17:59:30
Its a 400
r4etired
10-25-2004 16:16:06
Post the casting code letter from the rear axle housing or rear end casting. It will help a lot
