One Thing is for Certain
Allan in NE
10-26-2004 10:59:59
Hmmmm,
Vendor thought that this port block off a 350D might work on this little pump if I machined it down a little. 'Taint a gonna work 'cause the oil feed holes are staggered thru the block and I'd be cutting into the passeages.
Okay, I gotta just stop and think a minute; there must be a way to do this..... :>)
Allan
third party image
Redmud
10-26-2004 13:56:11
 Re: One Thing is for Certain in reply to Allan in NE, 10-26-2004 10:59:59
Allan, looks to me like you could drill and tap through each end, and pipe plugs are cheap.
Redmud:
Allan in NE
10-26-2004 14:01:57
 Re: One Thing is for Certain in reply to Redmud, 10-26-2004 13:56:11
Hi Red,
Yes, I just got back from kickin' on every machinist’s door in the county; nobody will touch it, so guess it is up to me.
Heck, doesn't look like that big a deal.
Thanks,
Allan
Harley1983
10-26-2004 17:18:46
 Re: One Thing is for Certain in reply to Allan in NE, 10-26-2004 14:01:57
Allan, the original offer still stands. If you can't get that thing to work, or it doesn't fit, just let me know and I'll take it back, no questions asked. I'm not going to sell a man a boat anchor who lives as far from the water as you do.Later, Harley
Sloroll
10-26-2004 13:38:01
Hey Allan Good luck with her. If you are ever down I-80 stop in. Been great meeting you. I think I'm off (didn't mean to offend and won't again) I'll fix you and your wife supper! I hope you don't have to worry about snow this year. Hs are the best. Bill
Andy Martin
10-26-2004 11:09:30
I'm assuming the block is too wide as it sits in th epicture, and a fly cutter cutting out only the radius on the pump to get clearance will cut into the passages.
It would be easier to make a new block out of aluminum than to build a standoff to clear the pump.
Allan in NE
10-26-2004 11:14:53
 Re: One Thing is for Certain in reply to Andy Martin, 10-26-2004 11:09:30
Andy,
You hit 'er right on the head. Plus, on an H, the ports have got to come out of the block at a 90 degree angle because the frame rail sets so close.
Do you think a machinist could build one of these gizmos?
Allan
Andy Martin
10-26-2004 11:22:29
 Re: One Thing is for Certain in reply to Allan in NE, 10-26-2004 11:14:53
It's an easy job. The o-rings are in the pump, so all you need is one flat surface. Cross drilling to bring the ports out the side is no big trick.
In aluminum I'd go with straight threads instead of pipe threads to avoid galling. Then buy straight thread adapters with o-rings. You can get a 90 degree elbow, straight thread one side and swivel female pipe thread the other. That way you can run cheap pipe thread hose.
