Override clutch for PTO shaft
JBlavl
10-27-2004 08:30:53
Just out of curiosity is there any special type of override clutch I should get for my Super C? What have you guys had the best luck with? and how much should I figure on spending and where can I pick one up. I was thinking about stopping at Tractor Supply and grabbing one. Will that be sufficient? Sorry for all the questions but the freshly rebuilt Super C is going to get a little action tonight.
Josh
Steve W (NY)
10-27-2004 11:47:07
 Re: Override clutch for PTO shaft in reply to JBlavl, 10-27-2004 08:30:53
I use on on my Ford, and it has a roll pin that you drive through the PTO shaft after you remove the grease fittings. Which means you can't take it off. I have seen a type that has a push button, just like a PTO shaft has to make removal easy. I plan to get that kind when this one wears out.
Take Care
Steve
Andy Martin
10-27-2004 13:50:27
 Re: Override clutch for PTO shaft in reply to Steve W (NY), 10-27-2004 11:47:07
Of course you can take it off, you just get a little greasy. I put one on every fall to brush hog and take it off every spring to mow hay.
I would steer away from the quick disconnect styles, as they are a little longer and will wiggle a little more. I find that the driveline works better the shorter and tighter you can keep it.
Jen
10-27-2004 10:17:47
I can sell you one of those. I offer both sizes. The cost is $48.50 plus shipping. (It's also called an over-running coupler.) But, suppose that won't help you if you need it today.
JBlavl
10-27-2004 19:24:47
 Re: Override clutch for PTO shaft in reply to Jen, 10-27-2004 10:17:47
Jen TSC didn"t have any in stock and they wanted me to order one. Send me your contact info and I will get ahold of you to purchase one. Thanks
Josh
JBlavl
10-27-2004 11:35:36
Thanks for the offer Jen but I was planning on getting one today. I just didn't know if there were certain brands I should steer away from. Thanks though.
Guy
10-27-2004 09:41:30
Just bought one at TSC last week. It was about $50. They had 2 different sizes, one for 1-3/8" PTO and one for 1-1/8" PTO. Well worth the investment if you are using a brush cutter.
Novel Idea Guy
10-27-2004 08:37:22
OverRUNNING clutch, perhaps? Mowing is about the only reason I can think of for an overrunning clutch. Instead of the mower's momentum driving the rear end of the tractor when you push the clutch, the mower spins free and the tractor stops.
I don't think you've got too many different ones to pick from; it's a limited market. Expect to pay what the price tag indicates, especially if you want one NOW.
