Stuck countershaft nut
David in UT
10-27-2004 15:13:33
Well, I've just about reached my frustration point, and I'm about to call in the big guns, which sometimes gets me in trouble. So, before I do that I wanted to see if there's anything else I should be trying... Here's the deal:
I'm trying to replace the oil seal on the countershaft of a '40 M. I've dropped the lift-all pump (in fact, the tractor is split so I've got complete access through the clutch housing), but I can't seem to get the countershaft nut off. I've engaged two gears to freeze the tranny, and I've given it everything I've got with a pipe wrench and extra leverage. I've pulled hard enough with the pipe wrench that I've scored the nut with the wrench's teeth. It's not budging...
I made up a tool by welding a 2-inch piece of 1/2 square bar onto a big ol' inch-and-quarter nut. I can now put this thingey into the countershaft nut directly and then turn the tool with a socket. I'm about to hit with with an impact wrench to see if that will break it loose, but there's a little voice in the back of my head saying CAUTION!
I know these trannies were built to take a beating, but how much risk am I taking to breaking the two gears I've got engaged? I could try bracing the countershaft with wood blocking, but I might end up driving the blocking in so hard that I can't get it out...ah...just answered my own question: I can drive the blocking out when I reverse the process and drive the nut back on.
Any thoughts or words of wisdom?
Thanks,
- David
Haas
10-27-2004 18:47:45
 Re: Stuck countershaft nut in reply to David in UT, 10-27-2004 15:13:33
Just a piece of 1/2 inch barstock in the slot of the coupling and some blows with a hammer in the counterclockwise direction should break it loose. Or use the impact wrench as others said. The vibration of the impact wrench or the hammer blows do wonders to break loose stuck threads.
David in UT
10-27-2004 16:24:45
Thanks guys...I'll let you know how it goes tonight.
parts man
10-27-2004 15:37:37
The impact would be the way to go. The jarring action of the impact should shock it loose.
Andy Martin
10-27-2004 15:35:26
I'd take it out of gear and use the impact wrench against the inertia of the countershaft.
It is left hand thread or right hand?
I really don't remember.
The impact does a lot of good without having the shaft held solid.
williamf
10-27-2004 18:44:57
 Re: Stuck countershaft nut in reply to Andy Martin, 10-27-2004 15:35:26
It's good old standard American - lefty loosy, righty tighty. We have a blade retaining nut on the paper machine where I work that the German engineers decided needed to be reverse thread. About the time we started to be able to remember that it was backwards our thoughtful management got the shaft replaced with a standard thread so that we wouldn't get confused.
Wm
