Tranny differential fluid
Dwight
10-28-2004 08:24:49
Can't find anything in my manual about what kind of fluid to use in my 51 Super C. Local tractor dealer says to use hydraulic fluid. Seems to be a lot thinner than what's in there now. Any reccomendations?
Peabody
10-28-2004 10:40:26
 Re: Tranny differential fluid in reply to Dwight, 10-28-2004 08:24:49
Holds right at 5 gallons.
Dave_Id
10-28-2004 08:56:07
80W-90 gear lube, but if you are in a much warmer climate, you can use 140w150
MN Scott
10-28-2004 08:54:42
You should use 80w90 gear oil, that or 90W is whats in there now. You can use hytran but you would have to replace all the seals because its so much thinner. You would also have to flush it out well as gear oil leaves sticky gunk in the transmission case.
Dwight
10-28-2004 20:31:38
 Re: Tranny differential fluid in reply to MN Scott, 10-28-2004 08:54:42
Thanks! I appreciate the help. I"ll go with the 80W90.
