Countershaft nut update
David in UT
10-28-2004 20:30:32
It's off!
It took I learned that I've got a wussy impact wrench...it didn't budge it. I had to borrow my neighbors gargantuan pipe wrench, then put a floor jack under the end of the wrench and jack it up so that the weight of the chassis would be applying torque.
Thanks for all the advice on getting it off.
- David
haas
10-29-2004 17:47:52
 Re: Countershaft nut update in reply to David in UT, 10-28-2004 20:30:32
Glad to hear you got it off!! First impact wrench I got was one of those $30 ones that came in a package deal with a compressor. I still have it but never used, it will barely take the nut off a 3/8 inch bolt. I went back later and got the strongest one I could find. Just the wrench cost almost as much as the previous compressor deal.
Kelly C
10-29-2004 10:18:46
Its funny that when it comes to working on old tractors. A simple strait forward procedure is seldom that.
Cant even count how many times it gets down to. " Ok just have to remove this bolt and thats done"
3hrs latter after after you go to the parts store to get a replacement for the bracket you had to cut off just to get at the bolt you needed. Or get the broken stud out ect ect.
Oh well, problem solving is a skill you use with this hobby.
David in UT
10-29-2004 10:59:31
 Re: Countershaft nut update in reply to Kelly C, 10-29-2004 10:18:46
Kelly,
Well said. Getting creative is definitely one of the best things about old tractoring.
Another example was the nut on the end of the crank -- after a week of failed attempts, I just gave up and welded a 6-foot piece of stock on it for some serious leverage. Nothing like working with torque values measured in yard-pounds instead of foot-pounds!
- David
Dick Davis
10-30-2004 03:01:17
 Re: Countershaft nut update in reply to David in UT, 10-29-2004 10:59:31
Do you suppose that the welding on the nut might have been a facter on it coming loose? My nickel Dick Davis
David in UT
10-30-2004 11:58:55
 Re: Countershaft nut update in reply to Dick Davis, 10-30-2004 03:01:17
DD,
It might have helped, although I started out just laying some beads on the nut to see if the heat alone would break it loose. Welding the stock onto it was my second try. If I had an oxyact torch, I think I could have gotten the nut a lot hotter (at least more evenly hot) than with the welder alone. Definitely a good thought though...if I could have used heat alone, I wouldn't have to grind my hacked-up wrench off the nut! ;-)
