Farmall F20 Hydraulic
SC Jim
10-29-2004 20:18:25
I am looking for a hydraulic pump for a Farmall F20. I believe that when the H came out, IH released a hydraulic "lift all" pump for the F20. I would appreciate any leads.
BIG JOHN
10-30-2004 17:35:16
 Re: Farmall F20 Hydraulic in reply to SC Jim, 10-29-2004 20:18:25
Char Lynn made a "Power Pak" which is a complete hydraulic unit add on. It can be put on the PTO or attached at the belt pully with some adaptors. It is complete and self contained, resorvor, pump, valve all in one.
I have a couple of them on an A & B.
I've seen them on E-Bay for about $200.
TMM
10-30-2004 03:45:16
I have a hydraulic unit I took off my f20 That I Would sell.
SC Jim
11-01-2004 17:26:43
 Re: Farmall F20 Hydraulic in reply to TMM, 10-30-2004 03:45:16
Thanks for the feedback. Can you describe the unit (i.e. attachment to tractor -- PTO, belt pulley, fan belt, etc.) It it an IH or aftermarket part? Also, about how much would you be asking? Thanks.
kfox
10-29-2004 22:58:39
I saw a F-20 with a lift all pump at a sale this last Spring. Couldn't tell if it was the exact same or not. Also, the F-20 came out with the lift in the rear end. I had a F-12 with this type of lift. ken
