766 gas thermo spring
waterloo boy
10-30-2004 21:32:49
need help for direction of travel of cold start flapper. bought new spring and somethings not right;tractor older than shop foreman,no manuels, 715 gas combine at dealers with same engine no help. need position of flapper counter weight cold,currently at 11 o'clock cold: 2 o'clock hot.
the tractor vet
10-30-2004 22:21:57
 Re: 766 gas thermo spring in reply to waterloo boy, 10-30-2004 21:32:49
That sounds about wright. the spring should keep the heat rise in the closed posision till it warm up our you increase rpm's. and closed is at the 11:00 posision.
waterloo boy
10-31-2004 06:54:51
 Re: 766 gas thermo spring in reply to the tractor vet, 10-30-2004 22:21:57
thanks so much,info was impossible to find through dealer,just needed to know all was well,foreman had me secure spring to lower pin with wire otherwise spring rotated away from pin rather than flipper moving. wire has flipper moving just wasnt sure if in right direction. tractor on bale processor all winter so I want it working properly. thanks again.
