Super A Serial # Tag
Garland
10-31-2004 15:46:15
I am repainting a Farmall Super A and the ser.#tag was destroyed in a earlier paint job,is there any way to trace the serial # 1947 to 1954 covers a lot of tractors,any help would be appreciated,if it's like the Deere's it's sol. thanks Gman
CNKS
11-01-2004 07:17:39
 Re: Super A Serial # Tag in reply to Garland, 10-31-2004 15:46:15
The actual number is stamped on the tag -- you should be able to see that even if nothing else is visible. Unless you mean they ripped the tag off and threw it away.
Jim Becker
10-31-2004 18:12:25
Curious, how was the serial tag destroyed by a paint job?
Hugh MacKay
10-31-2004 18:09:20
Garland: Actually as Tom said engine serial number will be very close, up to serial number 310300, after that there becomes a spread of 2,000 between tractor and engine serial numbers. Engine serial number is stamped on a flat machined surface just under number 1 spark plug.
To see if you have an original engine go to casting codes. They are the numbers on each casting, separated by what looks like round head screws cast right into part. It gives the day and month by number and year by letter. X is 52, Y is 53, Z is 54 and A is 55. V was not used You can go both ways from that. If your codes are same or close, good chance tractor is original. Codes will actually preceed the manufacture date of tractor by a bit. The 8 separate castings will each have a code so go with the majority.
Garland
11-01-2004 18:09:09
 Re: Super A Serial # Tag in reply to Hugh MacKay, 10-31-2004 18:09:20
Hugh thanks a lot,Ill check tommorow,it's got the high and low pedcocks on the oil pan and the breather tube is the small one leading me to beleive it is an early Super A,I bought the tractor just because the gentleman was a life long friend and helped me in the Lodge,thanks again. Garland
SAVTom
10-31-2004 17:21:15
I believe the serial number is also on the block behind where the magneto/distributer is. That should work as long as you don't have a replacement block.
Tom
Super A
10-31-2004 18:05:49
 Re: Super A Serial # Tag in reply to SAVTom, 10-31-2004 17:21:15
The engine and chassis number won't match on a tractor that new. IH ended that practice during the A/B production period.
Al
Hugh MacKay
11-01-2004 02:41:09
 Re: Super A Serial # Tag in reply to Super A, 10-31-2004 18:05:49
They match closely until serial number 310300. That is the point when new type block was introduced.
