Farmall 350 Starter Question
Ken(IL)
11-01-2004 07:07:56
Guys,
We have a Farmall 350 that has been converted to 12V. We have a recurring issue with the starter. When the tractor sits for a few weeks without use, the starter quits working. You here a clicking noise and that is it. We have to drag it and pop start it to get the tractor running. The battery has a full charge. It works fine as long as week use it regularly. The problem is after it sits a while. Is this a problem with the bendix? I would think it would be more consistant if it was. Anyonw have any thoughts? If it is the bendix, how difficult is it to fix? Thanks
Ken
PUTTER
11-01-2004 09:06:01
 Re: Farmall 350 Starter Question in reply to Ken(IL), 11-01-2004 07:07:56
I had a similar problem with my 340. After checking all connections still click,click. I changed the sonenoid switch and fixed problem. If yours has one I would change it out, costs about 20 bucks. LOL PUTTER
Allan in NE
11-01-2004 08:47:02
Ken,
If you're hearing a stuttering or "clicking' noise, that sounds like a low battery. I'd have it tested.
Allan
CNKS
11-01-2004 07:13:35
Probably corroded cables and connections. How do you know the battery has a full charge after several weeks? -- Unless you charge it first, it has probably lost a lot of it's charge. Can you jump start it?
Ken(IL)
11-01-2004 08:31:23
 Re: Farmall 350 Starter Question in reply to CNKS, 11-01-2004 07:13:35
CKNS,
Thanks for the response. We always disconnect the battery when the tractor is not in use, and charge it before using after any down time. That is why I am certain it is not the battery. I was considering the connections, or maybe ground to be an issue. I am not very good with the electrical side. Have no problems with the mechanical side. I guess I will start by making sure the connections are all good and take it from there. Thanks again for the resonse.
