belt pully diameter?????
Warren Opp
11-01-2004 10:13:56
I need to know what would be the correct size belt pully for my W-9 and SMTA. Any help would be appreciated. Thanks Warren
Joe Evans
11-01-2004 20:12:52
 Re: belt pully diameter????? in reply to Warren Opp, 11-01-2004 10:13:56
Pulley diameters listed for the W-9:
8-1/2, 9-3/4, 11, 12, 13, 14, 15, 16-1/2, 18, 19-1/2. All are 8-1/2" face width with the 14" being the standard size supplied with the belt pulley attachment.
rustyfarmall
11-01-2004 11:15:50
Several different diameters were available to allow you to achieve the belt speed desired (in feet per minute). Different machines required different belt speed.
Joe Evans
11-01-2004 10:21:14
Warren: with respect to the W-9, there really is no 'correct' diameter. The reason I state this is that there are about 8 diameter options listed for the W-9 in the operators' manual. Going on memory, I believe the standard diameter is 14". I will try to remember to look this up and post again when I get the manual in hand.
I don't know about the SMTA.
sammy the RED
11-01-2004 10:35:44
 Re: belt pully diameter????? in reply to Joe Evans, 11-01-2004 10:21:14
On the Super M-TA:
11 x 7 1/2
12 x 8 1/2
13 x 8 1/2
