'62 IH 404 - Just got it
62-404
11-01-2004 11:54:20
Just got a IH 404 tractor on Friday to replace my little '57 Cub LoBoy. All seems ok, but was using it last night to pull the kids around trick-or-treating and after about an hour or so, it started sputtering and backfiring like mad. Sometimes would barely hold an idle even with throttle wide open. Prior to that it had run a post hole digger and driven on open road with no issues. Fuel is full & clean, sediment bowl is clear, etc. Any suggestions on where to look next? Haven't gotten the owners guide yet. Thanks!
jk
11-03-2004 16:20:51
 Re: '62 IH 404 - Just got it in reply to 62-404, 11-01-2004 11:54:20
hey
i have a '61 404 and a 67 ih 2404. i'd love to see a pic of your 404
62-404
11-04-2004 04:46:10
 Re: '62 IH 404 - Just got it in reply to jk, 11-03-2004 16:20:51
I'll take some later today and send them to you. Drop me your email address...
jk
11-06-2004 17:11:45
 Re: '62 IH 404 - Just got it in reply to 62-404, 11-04-2004 04:46:10
my email adress is joel_kurowicki@yahoo.com i look forward to seeing your pics. i have a pic of mine i'll find it and scan it if u want to see it.
catmandoo
11-01-2004 17:39:54
don"t know what part of the country your in but my guess would be carb icing.my 460 utility is good for it for about the first half hour i mow with it,it will start to puff a little black smoke and start to lug down and run like crap,i usually just power down and let it set and idle for a little bit and it will come out of it.to check run it for awhile and then feel the carb base where it meets the intake,my bet is shes good and cold.
62-404
11-02-2004 07:32:29
 Re: '62 IH 404 - Just got it in reply to catmandoo, 11-01-2004 17:39:54
I am in CT... I removed the carb this AM and cleaned out the bowl and such to see if the float was loaded. There was some scale and varnish in there so I cleaned it up and made sure the needle valve was clean too. Unforunately, made no difference. It runs ok at WOT, but less than that and it backfires and sputters like mad. Ugh!
