Pulling the flywheel off the crank
Alberta farmall
11-02-2004 11:17:21
This is the second flywheel and crack that I have purchased for my 1949 Super A. Distroyed the first one trying to take it off. Can someone help me to get it off in one peice?
El Toro
11-03-2004 06:12:50
 Re: Pulling the flywheel off the crank in reply to Alberta farmall A, 11-02-2004 11:17:21
After reviewing that picture in my IH manual I see a split bearing puller being used behind the pulley. They're using a 2-legged puller to pull from the split-bearing puller. Apply heat to the hub while tightening. Hal
El Toro
11-03-2004 05:41:10
If you're trying to pull the crankshaft pulley
my IH manual shows a 3-leg puller being used. Heat the hub of the pulley while tightening the puller. The flywheel is on the other end of the engine that has your clutch bolted to it. Hal
John in NE.
11-02-2004 18:47:01
I just came in the house from putting the engine from my 'B' on an engine stand.On the 'B',and I am just assuming that an 'A' is the same,just remove the pressure plate and clutch disc,then you can see the four bolts that fasten the flywheel to the crank,remove them and the flywheel should pop off rather easy.You have removed the pressure plate haven't you? John.
Haas
11-02-2004 14:39:01
Are you talking about the flywheel which is at the back of the engine, or do you mean the pulley on the front end that runs the radiator fan??
lee
11-02-2004 13:16:47
it's not even clear what you are trying to remove.
scotty
11-02-2004 12:36:27
Alberta, That crank pulley can be a son of a gun!!! What you need is a split bearing puller. The puller needs to go behind the meaty part of the pulley, because if you try to pull from the fan belt groove you will crack that pulley easily. I believe Northern Equipment will have the puller you need. Some heat applied to the pulley will help also. I hope this helps, I know your frustation, because I had the same problem.
scotty
captaink
11-02-2004 11:28:10
How are you trying to get it off now? Knowing that will help us help you figure out what to do differently to get it off.
