Army Corp of Engineers I-6
John M
11-02-2004 18:42:43
Found what is an Army Corp of Engineers I-6,tags on the fenders are somewhat of a mysyetry as only one is legible,barely,and had somethings along the lnes of Army Corps of Engineers,a few numbers stamped on it including the serial number,and barely legible is International Harvestor Company,the two others are not readable.On the engine is a small square tag with the name of a a compny which rebuilt the engine,but cant make it out.The original serial number tag was moved up and another tag iunstalled below it,cant read it.(Wish they used more aluminum tags).The oil filter housing was removed and replaced with a different type of filter,make unknown,but it mounts where the starting tank would have been wit a line from the engine to it and then back.The hood had no provisions for gauges as they usually do.The temp gauge was on a bracket near the engine,looked homemade.The oil pressure and amp gauge,light switch,starer switch,and on/off switch was in a oval box much like the ones Ive seen on 650s and the like.Other the these minor difference,it was basically an I-6.Large hooks had been added to the front axle and at the drawbar supports.Anyone ever come across anything like this.Pics soon!
JohnG(TX)
11-03-2004 06:27:53
 Re: Army Corp of Engineers I-6 in reply to John M, 11-02-2004 18:42:43
The oil filter liiks like a Luber-Finer. One of my M's came with one, and I found another somewhere else, however, mine bolt to the block inplace of the original filter housing.
Andy Martin
11-03-2004 06:04:20
The front cast frame rails and seat position look like my O-6, but the O-6 has solid cast front wheels.
The O-6 has the oil/temp gauges in the usual location but no opening for the steering shaft in the hood. Do you have the hood?
COE would probably have been special order. I have a CAT 12 grader that is COE. The Army tag gives the P.O. number, date of purchase, serial number, COE serial number, lifting weight, etc.
John M
11-03-2004 02:14:15
 Re: Army Corp of Engineers I-6-pics link in reply to John M, 11-02-2004 18:42:43
Heres some pics of this tractor.
David Manring
11-03-2004 15:58:00
 Re: Army Corp of Engineers I-6-pics link in reply to John M, 11-03-2004 02:14:15
John, thanks for posting the pics. That is similiar to my 1941 WD 6 . That elc. box I have seen on other I tractors. That is a lubefiner filter like they said.I think the Ordanace specifyied those to be like the other units(in the service) they had them on.
