sc electrical ?? help
stu in nj
11-03-2004 08:26:45
I keep haveing to replace voltage regulator they last about 3-4 months and then stop charging.I think i'm not doing something right! This tractor runs 7 days a week 2-3hr. Thanks for any and all help stu.
Bob M
11-03-2004 12:03:59
 Re: sc electrical ?? help in reply to stu in nj, 11-03-2004 08:26:45
Stu - Do you know what inside the regulator is failing (contact points, relay winding burning out, etc)? That will provide a clue to what is causing the failures.
A few possibilities: Are the tractor electrics connected positive ground? (Regulator may have shortened life if the system is neg ground). Does the tractor have a stock generator, AND are you using the correct regulator number? (Gen and reg must be matched to each other) If the generator has an adjustable 3rd brush is the 3rd brush set correctly?
stu in nj
11-03-2004 13:39:23
 Re: sc electrical ?? help in reply to Bob M, 11-03-2004 12:03:59
Bob gen and reg are matched and positive ground it does not have 3rd brush. I think it's the contact points if I tap on reg it works. Out of 5 tractors this one is driveing me nuts!
Bob M
11-03-2004 16:48:24
 Re: sc electrical ?? help in reply to stu in nj, 11-03-2004 13:39:23
Stu – You sure you’ve got the stock generator? Far as I’m aware all SC’s use a Delco 3rd brush 6 volt gen – the later ones with a non-adjustable 3rd brush. I’m thinking if your gen is a 2 brush it could be overloading and burning the regulator contacts.
stu in nj
11-03-2004 17:11:32
 Re: sc electrical ?? help thanks bob in reply to Bob M, 11-03-2004 16:48:24
This is the generator that came with the tractor i'll try to get # off it and match a new regulator to it. I gess it was replaced and I keep buying a stock reg hope this does it! Thanks for youre help i'll let you know if it works stu.
