Order Farmall Cub Parts Online
Repairing a cub
1951G
11-03-2004 10:43:52
I just bought a 49 cub and it's going to need a lot of work. Some of the problems I'm not sure how to fix and need some helpful advice. The radiator has a hairline crack across the bottom tank. I was thinking of making a v cut on the radiator and filling it in with jb weld to fix that problem.
The gas tank has a 1 inch hole in the top. I was thinking of cutting a square hole where the existing one is and somehow welding another piece of metal there. Someone told me to do this and fill it back in with bondo before painting. Has anyone done this and how has it turned out? Thanks in advance for any help.
Gene
11-03-2004 12:03:39
 Re: Repairing a cub in reply to 1951G, 11-03-2004 10:43:52
A new Cub radiator costs around $130.00.
Welding the gas tank. Can be done. Remove the tank from the tractor. Rinse out with water - rinse until all traces of fuel are removed. Let the tank air dry with the sediment bowl and cap off for several days. You want to remove all of the fuel fumes. Vacuum cleaner on exhaust for several hours will speed up the drying out process.
I used to teach metal shop and we (students) have welded up many gas tanks. Form a patch larger than the repair hole yet smaller then the filler opening. Put a small hole in the center of the patch. Stick a long piece of wire through the small hole in the patch, crimp the wire below the patch. Fish the wire through the filler hole and back up through the hole to be repaired. Pull the patch tight to the hole. Braze or wire weld the patch to the hole.
Andy Martin
11-03-2004 15:32:01
 Re: Repairing a cub in reply to Gene, 11-03-2004 12:03:39
Letting the tank dry for several days is a little risky if it has lots of rust in the bottom. You can generate fumes after you thought it was clean.
For a novice, clean the tank as described, then refill the tank full of clean water, with just a little air right under the patch (patch on top) so you only have a small volume to explode if your cleaning was insufficient.
This also works well on 55 gallon drums you want to cut the top off of or weld a nozzle into.
captaink
11-03-2004 11:28:24
WARNING: Gas tanks and welders have explosive results if you don’t know what you are doing! I would strongly suggest if you must follow this plan, find someone else to do it.
Your JB weld idea will probably work. If you are an accomplished with soldering that would be an option to consider also.
