Where do you get 6V headlight bulbs for a BN
Steve W (NY)
11-03-2004 12:24:24
Just curious....is that like somehting the local NAPA would have or is it special order?
Take Care
Steve
Brian Schmidt
11-03-2004 15:23:26
 Re: Where do you get 6V headlight bulbs for a BN in reply to Steve W (NY), 11-03-2004 12:24:24
I bought a box of 20 from NAPA. Think they were like $2 each. I have found them at other stores though. Some low voltage lamps use these. I bought a box at an auction. Think they were Phillips brand and the packages showed a card of 2 was like $1.80. Shop around or go to NAPA.
Dave BN
11-03-2004 15:18:08
Got mine at my Case/IH dealer. They are much brighter than the bulbs that were in there. They are shaped like a small spot light and cost $5 each (ouch). Dave.
Bob M
11-03-2004 13:49:03
Steve - My local parts places (Rochester 'burbs) do not stock but can order. The more rural NAPA's however are likely to keep a few in stock.
I did find them at Schnabel's (Buffalo Rd in Rochester) a couple years ago. It's a #1133 bulb if I recall correctly.
rustyfarmall
11-03-2004 13:00:07
Your local NAPA should have them, I have even found them at O'Reillys. Your best bet however would be your Case-IH dealer, or you may even be able to order them right here from YT.
