whats up with the six
686
11-03-2004 19:17:35
what was IH thinking when they came out with the 686??? junk brakes ,junk t/a ,junk wheel clamps,and it dont even run that good..
ed1
11-08-2004 10:36:10
 Re: whats up with the six in reply to 686, 11-03-2004 19:17:35
Sounds like you woke up on the wrong side of the bed.
1.) My 686's brakes work fine and stop real good. Did you ever overhall the brakes and make sure everything is still their and working. I'll bet someone tried to adjust the brakes and broke off the adjuster or took them apart and lost the steel balls inside. It could be that after 25 years the brake disc's are simply worn out and need to be replaced.
2.) regarding the T/A, your correct it's an old design that originally came out with the SMTA. It works great in the field but freewheeling on the low side is a problem when towing a trailer. Also if the T/A clutch burns out the tractor will allways be in low.
3.) Wheel clamps are a problem. If you go out and get 4 new clamps with the cast in key and 8 new bolts you'll see a big improvement. Also use a 10' pipe on the end of a IH lug wrench to tighten. Don't worry its hard to snap 3/4" grade 8 bolts and if you do they should have been replaced anyway. If you strip the cast clamp then they should have been replaced.
4.) The D-312 engine was one of the best and in the same extended family as the 414/436/466 just smaller. The overall design, injection pump, oil filters,and water pump are all the same. Only problem was the wet sleve engine design that was later fixed with the DCA4 coolant additive and water filter. This problem wasn't limited to IH but all brands of wet sleve engines.
What was IH thinking when they came out with this tractor - survival. They were really starting to feel the profit crunch in the late 70's and didn't have the $$$ to bring out some of their inovative designs.
The original design dates back to the 1930's model "M" with a lot of improvements. If IH put in a shift-on-the-go transmission like John Deere and more gears especially in the prime tillage range it would have been an outstanding tractor instead it's a good tractor. The 3 point lift capacity on this tractor is in the 6,000 plus range - NH's new TL80A (about the same HP) can only lift 5,600 lbs. The hyd system is also rated at 23 GPM better than some newer tractors. Row crop visability is also better than NH's TL80A.
If this tractor came out in 1950 it would have been inovative. In the 1970' it was a good tractor with an old design.
Allan in NE
11-04-2004 04:49:24
Hi 686,
Yes, someone should have warned you in advance.
You'd better get rid of it. Take a loss if you have too; just dump it so that you don't have to put up with this aggravation. Get away from it as soon as possible.
No one should have to go thru this kind of stress. :>)
Allan
Nebraska Cowman
11-04-2004 03:31:12
I have two, A 656 gear drive with M&W turbo and an 86 Hydro, I have to be real careful not to slide the tires when coming down my paved driveway with a load of hay. Maybe yours just needs a good owner, do you want to sell?
Hugh MacKay
11-03-2004 21:52:23
686: If your just now discovering a 686, you've led a rather sheltered existance. Probably not safe to let you go to town by yourself. 686's are now all over 25 years old, and have a bit of history behind them. Any 25 year old tractor with a poor maintainence record will not look good. And yes I can tell it has seen poor maintainence or your wouldn't be craping about the particular items you have outlined.
656, 666 and 686 in good order can not be matched by any 60 hp tractor on the market, even to this current day. I know of several of these tractors going over the 10,000 hour mark with almost no repair bills. Fuel efficiency was top notch on both light and heavy work. I owned one of them, truly the most efficient tractors ever built. I also owned 15 other Farmalls, all bought new by my dad, my neighbor or myself.
All I can say is; your ignorance is showing.
Hugh MacKay
11-04-2004 11:35:53
 Re: whats up with the six in reply to Hugh MacKay, 11-03-2004 21:52:23
I know a bit about Deere brakes also. When they get bad you don't rebuild them in 1 hour per side. I owned Farmalls 300, 504, 560D, 656D, 1066 and an articulated Deere. The most efficient horse power of the bunch was 656 with 560 close second. I'm not talking about the best, I'm talking efficient. I will put the Deere in 3rd place. By the way those six tractors clocked a total of 85,000 to 90,000 hours for me. I do know my fuel and repair cost per hp hour for each.
686
11-04-2004 10:48:19
25 years old??we are not talking about cvt trannys. tractors had power brakes since at least 1960..compare to a 730?? YOUR ignorance is showing.late 50's? early80's? no time for progress there.5 speed transmission that runs off downhill if in low ta. I dont have a problem with IH's, it is my newest tractor and is a total letdown. I have a 1456,1466,4520,and a 2020 with by the way has the best brakes of the bunch.
scotc
11-04-2004 17:07:43
 Re: whats up with the six in reply to 686, 11-04-2004 10:48:19
All the early(ramp-style) torque's overran in low going downhill, shouldn't the 686 have the hydraulic shift t/a? sounds like maybe the fluid is a bit low or low side is gone(which around here seems like the side to go even if never used) or maybe this one was spec'd out as a bare bones machine. I know my SM will skid a tire with nothing behind it sometimes when the expander ring needs new neverseeze.
Allan in NE
11-04-2004 12:42:07
686,
Your 'newest' tractor is still at least 25 years old as Hugh says.
If the brakes are not up to par, it is your tractor that needs repair, not the design from IH.
They just are not a very big tractor (something like 64 horsepower @ 8500lbs?), they fall into the smaller of the chassis designs and they sure don't demand the implementation of power brakes.
Now if ya wanna compare a 686 to that precious 2020, you are going to be surprised because the 2020 cannot carry the 686's lunch-box; power brakes or no power brakes.
Allan
686
11-04-2004 19:19:56
 Re: whats up with the six in reply to Allan in NE, 11-04-2004 12:42:07
boy you guys are a tough crowd. I just though it was a cheap design thats all.geeezlueeezz.And by the way it is not a hydro t/a.hydro t/a's worked great,I thought a tractor this new would have newer design. The local mechanic said the drum brakes of old were better than those disc brakes.Also if the wet disc brakes were a bonehead design why did every on follow?can you say 1566?I dont care what color the tractor is they all made junk and had poor designs that just did not work/2010/ thats how it is man dont get all huffy.My newest tractor is that old and I like it that way I dont know about you guys but that electronic stuff scares me.
Hugh MacKay
11-05-2004 01:50:24
 Re: whats up with the six in reply to 686, 11-04-2004 19:19:56
686: I have an experience I wish to share with you. I had parts from Deere wet disc brakes, break up and go into the planetary. Planetary not being very forgiving when it comes to space, broke the bottom out of the axle housing.
You speak of being nervous on new electronic gadgetry, quite agree with you on that one. Computer was going to tell us what was wrong before man's eye would ever see it. It doesn't work. I am 62 and have yet to see my idea of the perfect tractor. While I say this I don't know as I've ever seen a tractor that didn't have at least one feature I liked. That is from the 8-10 American manufacturers around in the 60s.
A lot of gadgetry of all nature on modern tractors is very nice, but can one make money using it?
old don
11-04-2004 15:43:11
Hey fellas let's back up the wagon here 686 neglegted to tell us what he's been doing with this tractor ie; pulling a 12T forage box or two 500bu gravity bed wagons to prompt this display of disgruntlement maybe we have to look at the law of physics ie;friction vs inertia and mass.2 cents.
K.B.-826
11-03-2004 19:29:36
We had a 686 for about 6 years. Like you, I think that the worst thing about that tractor is the lack of power brakes. The TA's weren't that bad, if you know how to use them. Wheel clamps, just be glad you don't own a 100 horsepower tractor with that style, just gotta keep an eye on them. As far as your engine not running well, that's a problem with your tractor. The two diesel engines offered in the 686 were bulletproof, and the gas engine wasn't that bad. What was IH thinking? You tell me where you can find a more versitile 65 horsepower tractor.
JonT
11-03-2004 20:00:24
 Re: whats up with the six in reply to K.B.-826, 11-03-2004 19:29:36
3020 JD
old don
11-04-2004 15:51:01
 Re: whats up with the six in reply to JonT, 11-03-2004 20:00:24
Don't even start on the 3020. Yuk! what a disaster?
Aces
11-04-2004 05:12:06
3020 ain't got a chance with a 656 666 686. As for the whell clamps try moving the wheel on a 730JD with thet dump screw thing thsy had.
Redman
11-03-2004 21:15:47
NOT!!!
