FARMALL H OR M BALL SPECIAL PRELEANER? HELP
Tanner Clark
11-04-2004 08:37:54
I wanted to make sure that the M model Glass Jar precleaner piece will fit the H model Precleaner assembly. Does it? I believe they both have the 2" pipe opening for it to fit on. Please let me know. THanks.
dupontwarrior
11-04-2004 10:17:01
 Re: FARMALL H OR M BALL SPECIAL PRELEANER? HELP in reply to Tanner Clark, 11-04-2004 08:37:54
The H pipe is 2" and the M is 2 1/4". C is 1 3/4" and dozers and bigger than the 450 is 2 1/2". I have all four sizes for sale as well as original Ball Special jars with the gaskets which you dont see much anymore, most have c racked or fell apart over the years. You can open and close each one an eigth of an inch bigger or smaller. try using thin walled copper tubing, pretty cheap, and wont rust in place. The smaller the opening the more valuable they are. Hope this helps, Shane
Eastsider
11-04-2004 09:00:13
Nope, they are not interchangable. The M pre-cleaner inlet is bigger. I don't remember for sure how much, but it is either 2 1/4" or 2 1/2" in diameter.
Tanner Clark
11-04-2004 09:04:02
 Re: FARMALL H OR M BALL SPECIAL PRELEANER? HELP in reply to Eastsider, 11-04-2004 09:00:13
Is there anyway to still use it on the H model? Maybe put some type of sleeve in it etc? Any ideas.
Nebraska Cowman
11-04-2004 09:47:34
 Re: FARMALL H OR M BALL SPECIAL PRELEANER? HELP in reply to Tanner Clark, 11-04-2004 09:04:02
tanner, you probibly could neck it down with a sleeve or maybe trade it for the right one. I guess I would trade if you wanted to pay the postage.
Allan in NE
11-04-2004 09:21:32
Tanner,
How's about an exhaust pipe reducer?
Allan
