SMTA Remote System
alfalfa
11-04-2004 11:14:13
I am in the process of restoring a SMTA. I have a hyd. remote that I thought I would install.
However, this tractor has a Charlyn P.S. unit installed & it connects to the right side of the valve body where the remote should tie into it.
My question is: Has anyone ever run into this ?
Can it be done & not look silly?
Should I just forget the remote installation?
Thanks.
MM_TX
11-05-2004 06:25:58
 Re: SMTA Remote System in reply to alfalfa, 11-04-2004 11:14:13
Thanks to Bob M this might help
Link
u=4001561&a=30088889&f=
Allan in NE
11-04-2004 14:40:24
Al,
I have an extra pump/reserviour, bracket, front crank pulley and a couple of used hoses to fit that Char-Lynn if you need 'em.
Allan
James H in Tx
11-04-2004 19:50:39
 Re: SMTA Remote System in reply to Allan in NE, 11-04-2004 14:40:24
Allen if he is not interested in the pump/reservoir e-mail me with a price. I need a pump for a M. Thanks
James
James H in Tx
11-04-2004 19:49:02
James
26Red
11-04-2004 12:16:08
Get a flow divider valve that give 2 gallons/min of flow to the charlynn torque generator. Check out Force America dot com.
Gressen KCFD-2 $150. 3/8" CF PORTS
Or get an adjustable flow control valve
FC-51 3/8" CF PORT $80.
You can also buy a separate powersteering pump from them to fit your SMTA but it is spendy!
the tractor vet
11-04-2004 11:28:59
Yes it can be done , but you will need a flow devider if you want everything to work the way it is suppose to .
