H Hydraulic Fluid
GAC
11-04-2004 16:25:40
What tpye of fluid do you use in an H's hydraulics
riverbend
11-05-2004 06:14:05
 Re: H Hydraulic Fluid in reply to GAC, 11-04-2004 16:25:40
You can use any hydraulic fluid or 30 wt ND oil. Use hydraulic oil if you are going to be sharing cylinders with any other tractor.
Wayne Swenson
11-04-2004 21:09:07
Original recommended oil was non-detergent 30 weight for summer use. I am still using this oil today because it is a heavier bodied oil than Hy-tran so will build more pressure. Less costly, too.
Hy-tran is an excellent product but is designed to best operate in systems with closer tolerances than the belly pump on your H.
David Wence
11-04-2004 16:30:25
You should use Hytran
