ihcw@peoplepc.com
David Wence
11-04-2004 16:55:04
I broke the tractor apart earlier this year to put in a new TA, it is a 400. And the hydraulic oil ran out about 2 gallons. I ran it for awhile and forgot to put the oil back in it. Just this week I put a loader on it and I can not get any pressure. I tried to prime the pump through the hole in the top and it bubbled a lot and I could hear a sucking noise but could not get the lines to fill up with oil. Does anyone know what the problem is? The tractor has not run any hydraulic implements for about 10 years.
Thanks,
David
Hugh MacKay
11-04-2004 17:18:51
 Re: ihcw@peoplepc.com in reply to David Wence, 11-04-2004 16:55:04
David: If you ran the tractor much more than 30 seconds without hydraulic oil, the pump is most certainly cooked. That oil not only performs hydraulic function, but lubricates pump as well. 30 seconds is the difference between a perfect pump and the cooked one.
I farmed for many years, had 16 different Farmalls, and have had them apart with oils drained many times. I have never primed hydraulic or oil pump in my life.
