turbo's
fredy
11-04-2004 19:37:01
Im an implant from another page but couldn't get any help there. I was wonderind are ther any turbos known to make a nice whistling sound? I have a air research TO4 on my [gulp] 4520 and it dosnt make any sound.I run a 3.5 inch pipe. Please no brand bashing Im just asking. thanks
fredy
11-05-2004 10:23:16
 Re: turbo's in reply to fredy, 11-04-2004 19:37:01
thanks guys,I never knew different pipes made the turbo sound different.
Bob M
11-05-2004 08:27:48
It's always amazed me the lack of turbo whistle on a buddie's stock 4520. Compared to other turbocharged stuff I use (JD 4455, 8300, 8960, 7700 combine; also Cat/Mack/Cummins-powered trucks) the 4520 is virtually without turbo sound.
On the other hand every other engine noise makes it into the 4520's aftermarket cab - it's far and away the noisiest cab tractor I've ever operated!
Cliff Neubauer
11-05-2004 05:39:46
I have replaced a couple of TO4 turbo's on IH tractors with Switzer 3LM turbo's which build another 2-3 psi of boost and create alot more turbo noise.
Redman
11-05-2004 04:46:37
try a 4 inch strait pipe about 3 1/2 feet long,a to-4 will whistle nice if you get the pipe the right length.
also for some reason a curved pipe don't work.
scotc
11-04-2004 20:24:14
Can't help with what to go to, but be careful what you wish for, our CIH 4240 running that old IH 4-cylinder turbo engine is cranked up to 105 engine hp(or pto???) and the turbo whines so bad I can't run the thing at speed for more than a half hour without my skull ringing for hours afterward.
