distributor to timing gear housing gaskets
jamiei
11-04-2004 21:02:12
anyone have the part numbers for these two gaskets? One for between the distributor (delco) and the dist shaft housing? and one between the dist shaft housing and the timing gear housing. I'm sure these names aren't correct for the parts but I'm sure you see what I mean. I'm installing a new m & w live pump and need the gaskets. Thanks to anyone that can help.
Allan in NE
11-05-2004 03:37:52
 Re: distributor to timing gear housing gaskets in reply to jamiei, 11-04-2004 21:02:12
Hi Jamie,
The Case IH numbers are: 55780-DE & 352439-R1
Allan
