Starter fuel tank on 44 H model, any issues to loo
Tanner Clark
11-05-2004 10:10:08
I am looking at getting another H model, specifically a Wide front end 44 model with a front end loader serial #1587253. It has the starter tank, which I believe means that it is a distilate setup. Is this correct? Also, are there any issues I should look for when purchasing a tractor with this set up? It runs, and everything seems to work fine. I'm just wondering about any red flags to look for.
FRANK CASWELL
11-05-2004 11:04:08
 Re: Starter fuel tank on 44 H model, any issues to in reply to Tanner Clark, 11-05-2004 10:10:08
TANNER; CHECK AND SEE IF THE MANIFOLD IS A ALL FUEL,IF SO CHECK THE LEAVER ON THE RIGHT SIDE OF THE MANIFOLD TO SEE IF IT IS FREE NOT STUCK, IF IT IS FREE I WOULD LIKE TO PURCAHASE IT. FRANK CASWELL, THANKS
rustyfarmall
11-05-2004 10:44:27
Nothing to worry about, the distillate engines used the lower compression head, which will ultimately result in slightly less horsepower, but you will never notice it. It's a safe bet that this tractor has been running on gasoline for most of it's life. There is no reason to consider this tractor any different than any other H.
Aces
11-05-2004 10:18:00
Tanner that is how it came new but who knows aftr all these years may have been changed.
Tanner Clark
11-05-2004 10:36:30
 Re: Starter fuel tank on 44 H model, any issues to in reply to Aces, 11-05-2004 10:18:00
Yes, well I know it still has the starter tank on it and it runs. I just want to know if there is anything to look out for with this particular set-up?
little john
11-05-2004 13:25:18
 Re: Starter fuel tank on 44 H model, any issues to in reply to Tanner Clark, 11-05-2004 10:36:30
I have a 44 "H" which had the distillate carb and extra gas tank for several years. It had no problems. I just traded for a gas carb and took off the small tank, mostly for fun. It runs just the same.
