Fast forth on a F-20 ?
Pete L
11-05-2004 18:35:30
Guys - - Is there a way to identify if an F-20 has a fast 4th gear by looking at the tractor? I'm not talking about the device beteen the clutch and transmission.
Thanx !
Pete L
11-08-2004 09:26:25
 Re: Fast forth on a F-20 ? in reply to Pete L, 11-05-2004 18:35:30
Thanx guys..... .
F-Dean
11-06-2004 07:01:01
If the gear pattern closest to the driver (rear) is 1-4-2, it has the slow 4th. If this pattern is 1-3-2, it has the fast 4th. Acutally, the 3rd gear in the "Fast" transmission is the same as the 4th gear in the "Slow" transmission.
JohnG(TX)
11-05-2004 19:44:41
Fast fourth is in the upper right corner, slow fourth is in the bottom center between 1 & 2.
I can send photos of the shifter pattern. On early setups, they used a standard shifter and ground the numbers off and restamped the new pattern. The part even got a new part number stamped on. I can send photos of this type also.
Pale Rider
11-05-2004 18:53:45
Yes. The shift pattern is different on an F-20 for fourth gear depending on whether it was a "high" fourth road gear that came with rubber tires or a "low" fourth gear that came on steel. The way I remember it one is to the right and up and the other is to the right and down. I"m at work right now or I would go out and look at the F-20 that came on steel I have sitting under cover waiting to be restored and let you know what I have. Someone, like Nebraska Cowman will know for sure.
