glow plugs d236/282
larry marek
11-07-2004 15:34:18
Is there a way to test the glow plugs w/out pulling them? Somebody told me you could do it with a multitester/ohms meter. Any body have any idea what kind of reading we're looking for, and how to go about doing this??
Bob
11-07-2004 15:49:49
 Re: glow plugs d236/282 in reply to larry marek, 11-07-2004 15:34:18
On diesel pickup engines, I use an ammeter.
The (+) lead gets hooked to the battery, and you touch the (-) lead to the glow plugs (with supply wire unhooked from glowplug) one at a time to see how much they draw.
Once you know what is normal for your unit, you can then compare the draw of each plug. Most of the time, they are all pretty close, or burned out (and draw nothing), but there is the occasional plug that will still work, but draws way less than it should.
On the Ford or GM diesels, typically each plug will draw 10 or 15 Amps. A year ago I checked out a 706 with the ammeter, but I don't recall what amperage those drew.
Allan in NE
11-07-2004 15:44:44
Larry,
The easiest way is to hook a test light to positive battery voltage and test them one at a time with all the leads disconnected. If the test light 'lights', they are generally okay.
Allan
