IH 966 what size engine
Dave L
11-07-2004 21:46:30
We bought a 966 tractor and every thing I read shows that it should have 414 on the block,but this one has 437, if this is out of something else does anyone know what it is? thanks..
K.B.-826
11-09-2004 19:03:27
 Re: IH 966 what size engine in reply to Dave L, 11-07-2004 21:46:30
The 414, 436, and the 466 are the 400 series engines. They are pretty much identical, other than the crankshaft/stroke. 966's had the 414 from the factory, but installing a 436 or 466 is pretty much a bolt-in deal. If you've got 437 stamped on the block, it means you have a "B" series 436, which came along in '79. There is a rumor going around that the last few 966's had 436 engines from the factory, just like a 986, but that would have been in '76, they would not have been "B" series engines yet.
captaink
11-08-2004 08:50:26
The 966 had a 414 engine stock, the 986 had the 436. Is the engine you have stamped 437, or how do you know it is a 437?
Just for your info, I converted the 414 in my 966 to a 436 by changing the crank and ordering in the 436 sleeve set. I also added a turbo off a 1066 and was very pleased with what I got for torque even without changing the settings on the fuel pump!
Allan in NE
11-08-2004 02:34:20
Dave,
I don't know exactly where the breakpoint was, but the later 9s have bigger engines.
I think all the 986s have the larger size too, although I don't recognize that "437". Thought that they were a 441 or some such thing. Dunno.
Is yours a black stripe, by chance?
Allan
xxdonxx
11-08-2004 02:31:29
414 is stock motor. a 986,1486,1486& some 2+2's used 436. same bore. longer stroke.
DaveL
11-09-2004 21:35:53
 Re: IH 966 what size engine in reply to xxdonxx, 11-08-2004 02:31:29
Thanks to all who responded. The seriel number on the tractor makes it a 1974 but the engine block is stamped "437" and the breather is on the top and comes down over the left side.
