300 Fast Hitch
Dick Davis
11-08-2004 03:21:34
Was the Fast Hitch on a 300 different than on a 350? Some time ago on this board a strong recommendation was made to use a 450 or 560 Fast Hitch on a SMTA vice one from a 400. The resaon was the 450 hitch was simpler and better than 400 - but I can't remember the details. So if that is all true can a 350 hitch be put on 300 without major problems? Hope this question makes sense. Thanks for any help. Dick Davis
Marvin(MN)
11-09-2004 21:45:37
 Re: 300 Fast Hitch in reply to Dick Davis, 11-08-2004 03:21:34
You can put the fast-hitch from a F-350 or F-460 on a F-300. No problem.HTH
Farmall450man
11-08-2004 11:01:31
The FH on the 350/450 and later had draft control. The attachment to the rear end was different between the two styles of FH. I don't think that the 300/400 version can be fitted to the SMTA or the 350/450. But I'm not sure about bolting the 350/450 version on a 300/400. The lift arm on the 300/400 version bolts to the top of the deck, so I believe it has a unique bolt pattern.
Van in AR
11-08-2004 06:08:01
I"ve seen both types, the only differance noted is the later hitches had the split wishbone and the recievers would swing in and out independantly from each other like a 3 point arm. Would seem better for 3 point adapters.
Van
Dick Davis
11-10-2004 06:21:11
 Re: 300 Fast Hitch in reply to Van in AR, 11-08-2004 06:08:01
Thanks Guys I'm almost clear on the question. LOL
