Farmall A charge all over the place
Andrew Z
11-08-2004 12:55:19
My 1945 A, is chargeing all over the place, in that I mean that the needle is bouncing all over the gauge and now all the lights are burnt out what would cause this to happen?
Thanks for the help!
Andrew
pete ellis
11-10-2004 18:11:41
 Re: Farmall A charge all over the place in reply to Andrew Z, 11-08-2004 12:55:19
I have found that blown bulbs usually come brom bad battery connections so you get a volt surge the bulb cant take
kent king
11-08-2004 13:25:51
I would look at the regulator first. Sounds like thats the likely problem. Could be a loose wire, generator or if so updated the alternator going bonkers.
