A wide front on a C
tractorptsguy
11-10-2004 05:33:55
I've been thinking about putting the wide front from a junk A I have under a C. Anyone out there ever done that?
gene b
11-11-2004 12:27:20
 Re: A wide front on a C in reply to tractorptsguy, 11-10-2004 05:33:55
Mite have to move the steering wheel a tad bit but it would work ok just dont go ditch jumping. Would get some looks but it is your tractor and you can do anything you like. The bottom of the radiator on the C is different than the A in th way it mounts but you would be able to figure something out. Have fun you would like my reduced size of the B for mowing yards.
earlschieb
11-10-2004 06:30:16
I have seen it done, I tryed to buy a Super C at an auction a while back, it had a widefront from an A on it. The widefront from an A is a little light duty for a C, you would be better off with a widefront from a C.
Dennis Stoeser
11-10-2004 19:47:02
 Re: A wide front on a C in reply to earlschieb, 11-10-2004 06:30:16
Considering that the steering shaft is on the opposit side of the tractor on an "A" versus "C" you must want to buy alot of "U-joints".
