C/super C weight
Kevin
11-11-2004 06:51:54
How much does a C weigh?
and how much does a super C weigh
720Deere
11-11-2004 12:19:01
 Re: C/super C weight in reply to Kevin, 11-11-2004 06:51:54
I know a few guys that pull Super Cs in the 3500 lb class. That is with no fast hitch, one set of front and one set rear weights.
sammy the RED
11-11-2004 07:50:40
My books put the weight of the C at 2761 lbs.
Super C at 2891 lbs. Narrow front end's.
Dale in Ar
11-11-2004 07:27:17
I am not sure about a regular C but my Super C weight is 3800-3900 depending on the scales.I have the fast hitch and a wide front on mine with wheel weights on the rear.I am probably at the top weight range without front wheel weights.With front wheel weights ,I probably would be at 4000 lbs.
Randy in NE
11-11-2004 07:23:11
According Guy Fay's Tractor Data book the C weighs 2780 without fuel or water. The Super C weighs 2900 lbs shipping weight. My C weighs right around 2900 lbs without wheel weights or fluid in the tires.
