DOES A INTERNATIONAL 340 UTLITY HAVE A PTO AND 3PT
Ryan L.
11-11-2004 09:15:20
HI I am looking at an internatioinal 340 utility and was wondering if utiliy tractors have pto's and a 3pt hitch thanks
Charlie V aka F20II
11-11-2004 21:21:45
 Re: DOES A INTERNATIONAL 340 UTLITY HAVE A PTO AND in reply to Ryan L., 11-11-2004 09:15:20
340's had two point hitch's, there is however a three point adapter that IH made that converts it to three point. As well there was some after market three points hitches that were adapted to some of this model tractor. I do know that the Farmall 404 an 504 series tractors had three point hitches with torsion bar top links. The 340 did have power steering an came with either Gas or diesel engine's, the diesel's rowcrop are pretty few an far apart. The problem with 340's are that they are to new to old an to old to be very new thus parts are somewhat hard to find in bone yards an Case/IH dealers still have some parts in stock but not alot. Sheet metal is the hardest thing to find for 340's, the 240 which is the next smaller has smaller sheet metal an the 460 has bigger sheet metal. You can still find sheet metal but you are going to pay alot, the white side covers an corners are the hardest to find along with light brackets. This is a very good tractor, I had one an work it for a number of years, I sold it last year to a IH chapter member who completely restored it, I road it this past summer after he finish an I still have a smile on my face from it :o)
genep
11-11-2004 19:18:15
I had a 340 Utility for about 15 years. It had an independent PTO, Torque Amplifier, and a two point fast hitch lift with three point adapter arms. I think it had power steering, but I can't remember for sure. It was a super dependable tractor. The worst fault I found with it was if the tractor tilted away from the hydraulic pump pick-up the pump would lose it's prime. I would have to get it back on level ground and loosen the pressure line at the pump to get the oil flowing again.
porky
11-11-2004 10:27:04
My industrial 340 has a live PTO and has 3point as well.
Nebraska Cowman
11-11-2004 10:24:31
i believe they were options and most do but you better check.
