Good Buy???
scott#2
11-11-2004 16:24:06
Super a rebuilt engine, no smoke, ih belly mower, ih cultivators under and rear, ih 1 share plow. Pretty straight, new tires, barn kept, everything works. Easy restore. $1,500.00 ???
JEB-Il
11-12-2004 14:45:24
 Re: Good Buy??? in reply to scott#2, 11-11-2004 16:24:06
How do you all figure this is such a good deal? There seem to be an awful lot of people in this world with more money than sense.
Hugh MacKay
11-12-2004 18:17:02
 Re: Good Buy??? in reply to JEB-Il, 11-12-2004 14:45:24
Jeb: It's a good deal because he can probably sell it for $2,500. tomorrow. Old small tractors still have value, because lots of people still have use for them. You start getting over 35hp and if the tractor doesn't have Live PTO and hydraulics plus draft controled 3 point hitch, it has little commercial value, especially if it is a gasser. Just a mantel piece.
Nebraska Cowman
11-11-2004 16:35:45
oh ya! I'd grab it in a heartbeat!
scott#2
11-11-2004 16:47:33
 Re: Good Buy??? in reply to Nebraska Cowman, 11-11-2004 16:35:45
Yea I did, just wondering how I did and what it might be worth, its on the east coast. Anything to watch out for on these units?
scott
CNKS
11-11-2004 19:25:52
 Re: Good Buy??? in reply to scott#2, 11-11-2004 16:47:33
You paid $1500, then that's what it's worth, but to answer you question, the price is a little on the low side. I'm not going to define "little".
Hugh MacKay
11-11-2004 18:00:59
Scott: If you don't already have a manual, get one right away. Check lubrication on fan and distributor drive. These two items tend to get neglected on these little tractors. If you don't have the manual, e mail me, I will send back directions on those two items.
I would change all oils and antifreeze. 10W-30 or 15W-40 for crankcase, (personally I like 15W-40) Hy tran for the hydraulics and 90W or heavier gear oil for transmission, final drives and steering box. Antifreeze to suit your climate.
Items Super A tractors seem to have wrong at 50 years of age: carburator needs kit, governor may need thrust bearing and or spring, check out electrical (wiring harness can cause as much grief as rest of it.), brakes. Better still you tell us what you think is not functioning properly.
David A
11-11-2004 18:35:03
 Re: Good Buy??? in reply to Hugh MacKay, 11-11-2004 18:00:59
Hugh,
Regarding the often neglected items on the Super A, I'm aware of the fan issue. What about the distributor drive? I'm afraid mine's been neglected for the 4 years I've had it.
Thanks,
David
Hugh MacKay
11-11-2004 19:56:53
 Re: Good Buy??? in reply to David A, 11-11-2004 18:35:03
David: At least you did prove me right, on items neglected. On side of distributor drive there are two small plugs designed for removal by use of a blade screwdriver. They are also threaded for a grease zerk. The reason zerks aren't there is the chance of getting too much grease. IH recomended doing this every 500 hours or 6 months.
I never install the grease zerks. Years ago a IH serviceman advised me to use white automotive grease. I buy it in squeeze tubes and apply through the hole with tube. I do it every spring.
David A
11-12-2004 18:04:56
 Re: Good Buy??? in reply to Hugh MacKay, 11-11-2004 19:56:53
Thank you Hugh. Now I can avoid that problem.
David
scott#2
11-11-2004 18:12:11
I'll probably get to it this weekend and check er all out and get back to you. Thanks to all for your help.
scott
