42 mod A electrical question
bsmosk
11-12-2004 18:16:50
Just bought a 42 mod. A/faa, ser#93007/1540. All components look original. If so is it 6 or 12 volts, pos. or. neg. ground? Any help is appreciated. Thanks.
DaveBN
11-13-2004 06:19:48
 Re: 42 mod A electrical question in reply to bsmosk, 11-12-2004 18:16:50
42 A should be 6V positive ground. The Neg battery wire should be run to the starter. You should have a generator with cut out relay mounted on top of it. Light switch should be mounted on steering post and should controll High/Low charge and Bright/Dim lights. That is the decal marking on the switch box. Let us know. Dave.
ugly in Tx
11-12-2004 20:19:29
First thing I would do is check to see whitch post wire goes to chassis ground. Then throw a meter across the posts to read the voltage.
New Collector
11-12-2004 18:22:43
Yours originally was 6 volt positive ground but could have been changed.
bsmosk
11-12-2004 18:56:41
 Re: 42 mod A electrical question in reply to New Collector, 11-12-2004 18:22:43
thanks new collector.If it were changed, what would i be looking for? terminals, markings? thanks again.
parts man
11-12-2004 20:02:59
 Re: 42 mod A electrical question in reply to bsmosk, 11-12-2004 18:56:41
The regulaters are ussually marked on the bottom as to voltage/ polarity, IF you can read it, and IF it is indeed the right one for the system on your tractor. A LOT of changes and mistakes can be made in 40+ years!!
bsmosk
11-13-2004 07:59:04
 Re: 42 mod A electrical question in reply to parts man, 11-12-2004 20:02:59
will check all suggestions. thanks boys. This is my first collectable. I am proud to be assosiated with you guys. Nothing says America better then a Farmall.
