1466 blowin oil
686
11-13-2004 19:20:27
i have 1976 1466 black stripe that blows oil out of the breather. the timing is correct and that "brillo pad" lookin thing replaced in breather. its not alot but still more than i like see.
Hugh MacKay
11-15-2004 02:59:05
 Re: 1466 blowin oil in reply to 686, 11-13-2004 19:20:27
686: Is your 2020 missing by chance, I'm thinking the 1466 may have sucked it in. haha
Randy SE-MN.
11-14-2004 06:47:44
If you reused the pistons, or the sleeves, or installed the rings incorrectly, you may have had the ring gaps "line up" on you on a particular cylinder allowing a clear pathway for blow-by.
El Toro
11-14-2004 04:04:08
Sounds like you may have a broken piston ring and compression is blowing into the crankcase. You may want to check the compression. Hal
JD790
11-13-2004 20:54:24
Sounds like overhaul time in the near future!
686
11-14-2004 01:23:24
 Re: 1466 blowin oil in reply to JD790, 11-13-2004 20:54:24
it was just rebuilt 1300 hrs ago. been like that since i've had it.
tommyw
11-14-2004 17:35:03
 Re: 1466 blowin oil in reply to 686, 11-14-2004 01:23:24
some of the ih engines have alot of blow by ,the 400 series seems to be the worst ,my 5088 has alot of blow by ,it has 4200 origional hrs .i would not worry about it.
Redman
11-14-2004 20:25:07
 Re: 1466 blowin oil in reply to tommyw, 11-14-2004 17:35:03
the 50 series had completelt different rings in them from the rest of the 400 series,they were called a free breathing ring they are thinner than the 66/86 series rings.
the 400 series do all have blowby but oil should not be dripping out.
it is possible that they converted it to the new style rings when it had its OH,and then it would be the same as a 5088.
RAS
11-15-2004 12:35:34
 Re: 1466 blowin oil in reply to Redman, 11-14-2004 20:25:07
Redman is correct and if it has the high serial number rings it should have the breather in the valve cover not the side of the block.
