TD 6 Starter
dej(JED)
11-15-2004 10:01:17
Does a TD 6 take the same starter as an MD?
Any help would be appreciated. I have been having starter problems with the nose cone cracking and was wondering if there are 2 different starters out there.
gene b
11-16-2004 03:44:12
 Re: TD 6 Starter in reply to dej(JED), 11-15-2004 10:01:17
Check your starter and see if the BENDIX is right hand or left hand someone mite have the wrong one installed on the tractor. You can reverse the leads on the fields to reverse the rotation of the armature of the starter.
JonWaltonTN
11-15-2004 11:23:43
I believe the starter on a TD-6 enters from the engine side as opposed the transmission side as on the MD. The rotation will be opposite. I tried putting a T6 starter on my MD and found this out. The nose cone is the same though, remove that and install it on your TD6 starter.
JerePa
11-15-2004 19:25:28
 Re: TD 6 Starter in reply to JonWaltonTN, 11-15-2004 11:23:43
TD6 starter - IH#47871D (DR779)
MD starter - IH#61061D (DR1108913)
WD9 & TD9 take the 779 starter also.
