Need info on 656LP
Hayne Matthews
11-15-2004 17:09:30
Found one for sale, running and in good shape, what is it worth? I have never seen one before, is it collectable?
Harold H
11-16-2004 06:41:37
 Re: Need info on 656LP in reply to Hayne Matthews, 11-15-2004 17:09:30
Hayne,
Is it a hydrostatic or gear dirve? Farmall or International? TA or no TA? If it is a Farmall hydrostatic it is good for variable speed jobs but not for heavy work. Gear drive about like a 560 with a good 3 point hitch. If equipped with TA it is the planitary type. Personally, I liked your Farmall B-450 better, but you will have a much more modern tractor with a F 656 with power steering, draft control, and IPTO all of which your B-450 did not have. Plus all parts are US and easily available. Burning LP is probably still cheeper than burning gasoline but will probably cost more than if it was a diesel. Your guess on value.
Harold H
